      0WR7-03J
      Erasing Dark Borders When Copying (Erase Frame)
      When copying documents that are smaller than the output paper size, frame lines of the documents may appear in the copied image. When copying thick books, dark borders may appear. <Erase Frame> enables you to erase these frame lines and dark borders. You can also erase punch holes in the documents.
      Place documents with punch holes on the platen glass. Placing them in the feeder may result in damage.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Erase Frame>.
      5
      Specify erasing type and width.
      Erasing the frames of documents
      1
      Press <Erase Original Frame> and set <Original Size>.
      If the size displayed in <Original Size> is different from the size of the document you set, press <Change> to select the size.
      2
      Enter the width of the frame to erase.
      Erasing the dark borders of books
      You can erase the dark borders both in the center and contour lines that appear when you copy facing pages in a book.
      1
      Press <Erase Book Frame> and confirm <Original Size>.
      If the size displayed in <Original Size> is different from the size of the book you set, press <Change> to select the size.
      2
      Press <Center> or <Sides>, and enter each erasing width.
      Erasing punch holes in documents
      1
      Press <Erase Binding> and select punch hole location.
      2
      Enter erasing width.
      6
      Press <OK>  <Close>.
      NOTE:
      If you want to adjust the width for each border independently, press <Erase Original Frame> or <Erase Book Frame>, and then press <Adjust Independently> to enter the erasing widths.
      7
      Press .
      Copying starts.
