      0WR7-03C
      Canceling Copies
      You can cancel copying while scanning documents or cancel waiting copy jobs.
      Canceling Copying While Scanning
      The following screen is displayed while scanning documents. Press <Cancel> to cancel copying.
      If you press on the control panel, the copy job is paused and then the message <<Stop>Select the Copy job you want to cancel.> and the list of the copy jobs are displayed. You can select the copy job from the list and cancel the job by pressing <Cancel>.
      Canceling Waiting Copy Jobs
      1
      Press .
      2
      Press <Copy/Print>  <Job Status>.
      3
      Select <Copy> from the drop-down list and display waiting copy jobs.
      4
      Select the copy job to cancel and press <Cancel>.
      NOTE:
      If you press <Details>, detailed information such as the number of copies and the Department ID is displayed.
      5
      Press <Yes>.
      Copying stops.
      6
      Press <Close>.
      If you press  on the control panel when copy jobs are waiting, all the copy jobs are paused and then the message <<Stop>Select the Copy job you want to cancel.> and the list of the copy jobs are displayed. You can select a copy job from the list and cancel the copy job by pressing <Cancel>. If you want to resume copying, press <Resume Copying>.
