Staple Jams in the Saddle Stitcher Unit (Booklet Finisher-V1)
Follow the procedure described in this section to clear the staple jam. The Booklet Finisher-V1 is optional.
Optional Equipment
Check before clearing staple jams
If a paper jam occurs at the same time as a staple jam, remove the jammed paper before removing the jammed staples.
Before clearing the staple jam, remove all output paper from the booklet tray.
1
Open the front cover of the finisher.
2
Pull out the saddle stitcher unit.
3
Pull the lever on the two staple cases toward you to remove them.
4
Lower the bracket on the staple case.
5
Remove all the jammed and protruding staples from the staple case.
6
Return the bracket on the staple case to its original position.
7
Insert the two staple cases into the saddle stitcher unit.
Make sure that the staple cases are firmly inserted.
8
Push the saddle stitcher unit back into the machine, and close the front cover of the finisher.
