To use the fax function
The optional product is required for faxing. System Options
<Send>
<Fax Settings> <Set Line>.
<Register Unit Telephone Number>.|
Configure the setting according to the fax option.
You can edit the line name that is displayed in the line selection screen using <Edit Line Name for Select Line Screen>. <Send>
<Fax Settings>You can change the display of the address list according to the selected line in <Default Address List When Selecting Line>. <Send>
<Fax Settings>You can set to display a destination's phone number on the screen or report in <Set Number Display>. <Receive/Forward>
<Fax Settings>You can set to automatically switch of the incoming fax and incoming call in <Select RX Mode>. <Receive/Forward>
<Fax Settings> |
