      0WR7-034
      Registering Multiple Destinations as a Group
      Multiple destinations registered in the Address Book(Registering Destinations in the Address Book) can be combined into a group. You can use this feature to send documents and back up data at the same time because different types of destinations can be registered in the same group. For example, you can register e-mail addresses and file server IP addresses together in one group, or fax numbers and I-fax addresses in another one.
      In addition to registering destinations such as e-mail addresses, you can register a Mail Box (machine's temporary storage space) in a group (Making Simple Edits to Files). For example, when you register a Mail Box in a group and send a scanned document attached to an e-mail, the document can be saved in the machine and checked later.
      To register a group that contains destinations for your own use, you need to log into the machine. Logging into the Machine
      1
      Press <Dest./Fwd. Settings> on the Main Menu  <Register Destinations>.
      2
      Press <Register New Destination>.
      3
      Press <Group>.
      4
      Press <Name>  enter the group name, and press <OK>.
      5
      Select the address list.
      You can create a group from the destinations registered in the selected address list. For example, if you select <Address List 2>, you cannot add a destination registered in <Address List 1> to the group. The created group is registered in the address list you select in this step.
      If you want to register a group that contains destinations for your own use, select <Personal Address List>.
      If you want to register destinations in a group which only an Administrator can edit, select <Address List for Admin.>.
      6
      Select the destinations you want to include in the group.
      If you want to select destinations from the Address Book, press <Add from Address Book>. If you want to select a Mail Box (machine's temporary storage space), press <Store in Mail Box>. Destinations in the Address Book and Mail Box can be registered in the same group.
      When you select <Add from Address Book>
      When you select <Store in Mail Box>
      7
      Press <OK>  <Close>.
      NOTE:
      When destinations are managed by access numbers, enter destinations (Restricting Access to Destinations Registered in the Address Book) after pressing <Next> in step 7.
