      0WR7-02X
      Switching the Displayed Language
      You can change the language and keyboard layout displayed on the touch panel display. If you switch languages frequently, it is convenient to use the <Switch Language/Keyboard> button. Follow the procedure below to show this button on the touch panel display.
      Showing the <Switch Language/Keyboard> Button on the Touch Panel Display
      1
      Press .
      2
      Press <Preferences>  <Display Settings>.
      3
      Press <Display Switch Language/Keyboard Button>.
      4
      Press <On>  <OK>.
      If you set it to <On>,  appears at the bottom of the touch panel display.
      Switching the Language with the Button
      1
      Press  on the touch panel display.
      2
      Select a language from the list and press <OK>.
      You can change the displayed language for each login user. Configuring Accessibility Settings (Personal Settings)
