      0WR7-00Y
      Making SMB Settings
      This section describes setup steps to share files and printers among multiple devices on the network utilizing the SMB protocol. Enabling the SMB server functions makes it possible for the Advanced Box to be used as a SMB file server.
      1
      Press .
      2
      Press <Preferences> <Network>  <TCP/IP Settings>  <SMB Server Settings>.
      3
      Select <On> in <Use SMB Server> and carry out the necessary setup.
      <Require SMB Signature for Connection>
      To set so that an SMB packet signature is requested when connecting to the SMB server, press <On>.
      <Use SMB Authentication>
      User authentication is conducted by using user information in the Advanced Box. To conduct user authentication, press <On>.
      <Authentication Type>
      Select the version of the authentication protocol. Press <NTLMv1> when you use mainly Windows XP/Server 2003. Press <NTLMv2> when you use Windows Vista/7/8/Server 2008/Server 2012. You can also select both.
      4
      Press <OK>.
      5
      Press     <Apply Set. Changes>  <Yes>.
