Paper Jams in the Inner Finisher
1
Check whether paper is jammed in output tray of the finisher.
If paper is jammed, gently pull it out in the direction of the arrow.
2
Open the front cover of the finisher.
3
Hold the lever (
![](./images/book_images/b_in_C0000_a.gif)
), and slide the inner finisher to the left.
4
Check whether paper is jammed in the inner finisher.
Lift up the guide at the entrance.
Return the guide to its original position.
When the Puncher Unit is attached:
If paper is jammed in the 2nd output area, gently pull the jammed paper out in the direction of the arrow.
5
Return the inner finisher to its original position.
6
Close the front cover of the finisher.
Continue following the instructions on the screen to proceed with the interrupted operation or continue clearing paper jams.
