Paper Jams in the Staple Finisher
1
Check whether paper is jammed in the finisher.
Open the front cover of the finisher.
Lift up the output tray paper supporter of the main tray.
Turn the green knob to feed the jammed paper to the main tray side.
If paper comes out of the outlet of the main tray, gently pull the paper out in the direction of the arrow.
2
Check whether paper is jammed in the delivery unit.
Open the escape delivery guide (  ).
If paper is jammed, gently pull it out in the direction of the arrow.
Lift up the first flapper (  ).
Return the first flapper (  ) to its original position.
Lower the escape delivery guide (  ).
3
Close the front cover of the finisher.
4
Open the cover of the buffer pass unit.
5
Check whether paper is jammed.
6
Close the cover of the buffer pass unit.
Continue following the instructions on the screen to proceed with the interrupted operation or continue clearing paper jams.
13WJ-0RY
