![](./images/global_images/1T0003419081/b_style_note1_L=en-GB.gif)
Confirm before handlingIf the optional paper deck is installed, pull it away from the machine.
Hold the green lever (
![]() ![]() ![]() The output unit only opens as far as indicated in the diagram.
If paper is jammed, gently pull it out in the direction of the arrow.
Close the output unit.
If paper is jammed in the upper area, gently pull it out in the direction of the arrow.
If paper is jammed in the lower area, gently pull it out in the direction of the arrow.
![]() ![]() If you cannot remove the paper, return the fixing unit to its original position, and gently pull out the paper from the bottom side.
Return the fixing unit to its original position.
