![](./images/book_images/b_in_C0002_01.gif)
Pull the lever to open the cover.
If an original is jammed, gently pull it out in the direction of the arrow.
![]() If you cannot remove the jammed original, proceed to the next step without forcibly removing it.
Turn the green knob counterclockwise.
Lift up the feeder, and check the position indicated by
