Step 1
Step 2
Set up the network environment not included on the Setup Guide. If you do not start the Setup Guide, start setting up from this procedure.
Step 3
Step 4
Step 5
TIPS
Setting from the Remote UIWhen you complete setup for the network environment, you can set up the machine from Remote UI efficiently. Starting the Remote UI
Saving setup time by importing data from other machinesIf you have any other Canon multifunction printer and save (export) its registered setup data to a computer beforehand, setup contents such as address book and paper type setting can be immediately used by importing them to the machine. Importing/Exporting the Setting Data
