Replacing the Staples of the Inner Finisher
1
Open the front cover of the finisher.
2
Pull out the staple case.
Pull the green handle to disengage the lock, and lift the case slightly upwards while pulling it straight out.
3
Remove the empty staple cartridge from the staple case.
4
Remove the new staple cartridge from its box.
5
Load the new staple cartridge to the staple case.
6
Hold the green handle on the staple case and push it in as far as it will go.
7
Close the front cover of the finisher.
The finisher may automatically perform dry stapling to perform staple repositioning.
13WJ-0L6
