Check the operation status of the machine before turning the power OFF. You can turn the power OFF even if the machine is executing an operation, but this may cause the operation to be interrupted or data to become damaged.
Make sure that no trash such as pieces of paper gets into the groove of the multiple sheet feed detection sensor. If trash does get in, remove it using a soft cloth.
Pull the top lever to open the document feed scanning area cover.
Gently open the cover so that you do not damage the platen glass.
Open the inner cover.
Wipe the document feed scanning area (the thin and long glass area).
Wet a soft cloth with water and wring it out well, then wipe the machine with it. Afterwards, wipe the machine with a soft and dry cloth.
![]() Wait until the moisture has completely dried before proceeding to the next step.
Close the inner cover.
Close the document feed scanning area cover until it clicks into place.
