<Management Settings>
<Security Settings>
<Authentication/Password Settings>
<Authentication Function Settings>
<Security Settings>
Jobs that are restricted by this setting are forcibly canceled on the machine.
<Security Settings>
Users may be blocked from logging in before a specified number of consecutive invalid login attempts if login operations are performed on Windows or other operating systems, or from applications that use FTP, IPP, SNMPv3, SMB, or WebDAV.
<Security Settings>
<Password Settings>
<Security Settings>
<Password Settings>
If the password has expired, the screen for changing the password appears, regardless of this setting.
<Security Settings>
<Password Settings>
<Security Settings>
<Password Settings>
This setting applies to personal authentication management, not to Department ID and PIN.
<Security Settings>
<Password Settings>
<Security Settings>
<Password Settings>
<Security Settings>
<Password Settings>
<Security Settings>
<Password Settings>
<Security Settings>
<Password Settings>
<Security Settings>
<Password Settings>
<Security Settings>
<Encryption Settings>
This setting applies to functions such as IPSec, TLS, Kerberos, S/MIME, wireless LAN, and SNMPv3.
The machine may not be able to communicate with devices that only support weak encryption.
Even if the use of weak encryption is restricted, it may be allowed depending on the certificate (root certificate).
For information on the algorithms prohibited when this setting is set to <On>, see Specifications.
