![](./images/book_images/pubnumbers/flk33_menu_en_US/b_key_Add.gif)
![](./images/book_images/b_in_arrow_right.gif)
If this is set to <Off>, print and scan jobs from a computer connected via USB cable cannot be performed.
Depending on the type of MEAP application that uses device such as a keyboard or card reader, you may need to set this to <On>. To check whether you need to set this to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
Depending on the type of MEAP application that uses USB external memory device, you may need to set this to <On>. To check whether you need to set this to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
