Customizing Settings/Registration
You can register shortcuts for frequently used Settings/Registration settings in <Settings/Regist. Shortcut>. By using the shortcut, you can display the settings screen directly.
<Settings/Regist. Shortcut> can be displayed on the top of the screen or on the Main Menu screen. For more information, see Customizing the Main Menu.
1
Press <Settings/Regist. Shortcut> on the Main Menu.
2
Press [Register].
3
Select the button in which you want to register settings.
You can select the assigned button to change the registered settings.
4
Select the settings to register as shortcuts and press <OK>.
If you do not want to register settings, select [Unassigned].
13WJ-034
