1
Press <Standard Size>.
2
Select the paper size and press <OK>.
1
Press <Custom Size>.
2
Specify the length of the <X> side and <Y> side.
![]() Press <X> or <Y> to enter the length of each side using the numeric keys.
![]() If you register the paper size you use frequently on buttons <S1> to <S5>, you can call them up with a simple press. Registering Free Size Paper (Custom Size Paper)
3
Press <OK>.
1
Press <Envelope>.
2
Select the orientation and type of envelopes.
If you changed the placement of the envelopes, press <Short Edge Feed> or <Long Edge Feed>, and select the envelope type.
If you selected vertical placement for Nagagata 3, press [Next], and specify the flap length.
Proceed to step 5.
![]() When using Kakugata 2, place it horizontally.
1
Press <Envelope>.
2
3
If you load envelopes with the flap (seal) open, include the length of the flap when entering the size.
4
Press <OK>.
If a screen other than that for specifying the paper size and type is displayedIf a message prompting you to adjust the paper guide is displayed, adjust the width of the paper guide again and press <OK>.
