![](./images/global_images/1T0003419081/b_style_note1_L=en-GB.gif)
This section describes how to load envelopes with the proper orientation, as well as procedures that you need to complete before loading envelopes. For a description of the general procedure for loading envelopes in the multi-purpose tray, see Loading Paper in the Multi-Purpose Tray.
Do not use envelopes that have glue attached to their flaps, as the glue may melt due to the heat and pressure of the fixing unit.
Prepare the Envelope Feeder Attachment.
Remove the Envelope Feeder Attachment A stored in paper drawer 2.
Adjust the left guide of paper drawer 1, and attach the Envelope Feeder Attachment B to the left guide.
Attach the Envelope Feeder Attachment A by aligning the protruding areas of the Envelope Feeder Attachment A with the holes on paper receptor located on the bottom of the paper drawer.
Prepare the Envelope Feeder Attachment A.
Paper drawer 1
Paper drawer 2
You can load up to 10 envelopes at the same time. If the envelopes are not fed properly even if they have been prepared according to the procedures, load the envelopes individually in the multi-purpose tray instead of loading several sheets together.
Do not print on the reverse side of the envelopes (the side with the glued areas).
![]() ![]() ![]() ![]() To change the orientation of the envelopes, load them as shown in the figures below.
When you print on envelopes, remove them from the output tray 10 at a time.
When using Kakugata 2, place it horizontally.
If envelopes become wrinkled, load the envelopes with the long edge of the envelopes facing the machine.
