Control Panel
This section describes the names and usage of the keys on the control panel.
<Quick Menu>
Press to display the functions which are registered in the Quick Menu.
Using the Quick Menu
<Main Menu>
Press to display the Main Menu in which buttons for the basic functions are placed.
Using the Touch Panel Display
Login user name
The user name that is currently logged in is displayed.
Touch panel display
In addition to the settings screen for each function, the error status is also shown on this display.
[Settings/Registration] key
Press to start specifying many of the settings for the machine, such as <Preferences> or <Set Destination>.
Numeric keys ([0] - [9])
Press to enter numerical values.
Entering Characters
[Energy Saver] key
Press to put the machine into sleep mode. The key lights up when the machine is in sleep mode.
Entering Sleep Mode
[Counter/Device Information] key
Press to display the total number of pages used for operations such as copying or printing on the touch panel display. You can also check the serial number of the machine, the version information of the security chip related to HDD data encryption, and other optional device information.
Checking the Number of Pages for Copy/Print/Fax/Scan
Brightness Adjustment key
Use to adjust the brightness of the touch panel display.
Volume Settings key
Press to display the screen when you want to adjust the sound volume for the fax communication or to set the alarm sound when an error occurs.
Setting Sounds
[Clear] key
Press to clear entered values or characters.
[Stop] key
Press to cancel copying, faxing, and other operations.
[Start] key
Press to start copying or scanning originals.
Main Power indicator
Lights up when the machine is turned ON.
Turning ON the Machine
Error indicator
Blinks or lights up when an error such as a paper jam occurs.
If the Error indicator maintains a steady red light, contact your local authorized Canon dealer.
Processing/Data indicator
Blinks while operations such as sending or printing are being performed. Lights up green when there are originals waiting to be processed.
[Reset] key
Press to cancel the settings and restore the previously specified settings.
ID (Log In/Out) key
Press this key to log in when personal authentication is necessary. After you finish using the machine, press this key again to log out.
Logging into the Machine
<Status Monitor/Cancel>
Press to check the status of printing or faxing, or to view the usage history. You can also check the status of the machine, such as the remaining amount of paper and toner, or whether any errors occurred.
Adjusting the Angle of the Touch Panel Display
You can adjust the angle of the control panel if the touch panel display cannot be seen clearly.
