Restrictions When Connecting to ColorPASS/imagePASS
When ColorPASS/imagePASS is attached, some functions are restricted on the machine. For more information, see the manual for ColorPASS/imagePASS.
Functions Restricted When Connecting to ColorPASS/imagePASS
Wireless LAN
Setup Guide
Connected Sleep
Forced Hold Printing
Encrypted Secure Print
Direct Print
Direct Print (JPEG)
WSD Scan
Mopria
Even if <RX Timeout> is set for each item in  <Preferences>  <Network> <TCP/IP Settings>, a timeout always occurs in 5 minutes.
In  <Preferences>  <Timer/Energy Settings>, <Quick Startup Settings for Main Power> is disabled even if it is set to <On>.
Even if <Forced Print of Recognition Information> in  <Function Settings> <Common>  <Print Settings> is set to <On>, the IP address is not printed.
When Using the Advanced Box
SMB cannot be used to make the Advanced Box available to the outside. Use WebDAV instead.
If the machine is set to send URI in the detailed settings for the Advanced Box, a port number (18080 when SSL/TLS disabled and 18443 when SSL/TLS enabled) must be added to the specified path to the folder.
Example:
http://192.168.1.21:18080/share/documents (To specify the "documents" folder under the shared space when SSL/TLS is disabled)
Select [WebDAV] to save documents in the Advanced Box of the imageRUNNER ADVANCE Series with ColorPASS/imagePASS attached.
To send documents to the Advanced Box of the imageRUNNER ADVANCE Series with ColorPASS/imagePASS attached, enter the following in [Host Name].
To send to the Advanced Box of another product with ColorPASS/imagePASS attached
When SSL/TLS is disabled:
http://IP address or host name:18080
When SSL/TLS is enabled:
https://IP address or host name:18443
To send from the machine with ColorPASS/imagePASS attached to its own Advanced Box (by using a loopback address to specify a destination)
In IPv4 format
http://127.0.0.1:18080
https://127.0.0.1:18443
In IPv6 format
http://[::1]:18080
https://[::1]:18443
When entering the host name
http://localhost:18080
https://localhost:18443
When sending documents from the machine with ColorPASS/imagePASS attached to its own Advanced Box, you may not be able to send them by specifying a loop back address if <Proxy Settings> in
<Preferences>
<Network> is set to <On>. In this case, enter the IP address of ColorPASS/imagePASS.
When Using the Remote UI
Before starting the Remote UI, configure the <Network Settings> items in <Fiery> on the control panel.
To start the Remote UI, start the Web browser and enter the URL below. The Remote UI starts when you click [Launch Remote UI] on the WebTools screen that is displayed.
http://<IP address of ColorPASS/imagePASS>/
When Using the Print Function
ColorPASS/imagePASS cannot be used together with the print function that is standard-equipped with the machine.
Other Restrictions
The machine with ColorPASS/imagePASS attached must be restarted each time a DNS dynamic update is performed.
When ColorPASS/imagePASS is attached, the machine cannot automatically obtain the IP address of the SIP server by using DHCP.
