Available Paper
The paper types that can be used with this machine are shown in the following table.
For available paper with options attached, see the specifications of respective options.
Supported Paper Sizes
Paper Sizes
Paper Source
Paper Drawer 1
Paper Drawer 2, 3, or 4
High Capacity Cassette Feeding Unit-A1
Paper Deck Unit-F1
Multi-Purpose Tray
12" x 18"
12 5/8" x 17 11/16"
11" x 17"
LGL
(8 1/2" x 14")
LTR
(11" x 8 1/2")
LTRR
(8 1/2" x 11")
STMT
(8 1/2" x 5 1/2")
STMTR
(5 1/2" x 8 1/2")
EXEC
(7 1/4" x 10 1/2")
Custom Size
(3 7/8" x 5 1/2" to 12 5/8" x 18" (98 x 139.7 mm to 320 x 457.2 mm))
*1
*2
Free Size
Yougatanaga 3
Nagagata 3
Kakugata 2
No.10 (COM10)
Monarch
DL
ISO-C5
*1 You can use custom size settings ranging from 3.86 x 5.83 to 11.69 x 8.50" (98 x 148 mm to 297 x 215.9 mm).
*2 You can use custom size settings ranging from 3.86 x 7.17 to 12 x 18" (98 x 182 mm to 304.8 x 457.2 mm).
Supported Paper Types
Chlorine-free paper can be used with this machine.
Paper Type
Paper Drawer 1
Paper Deck Unit-F1
Multi-Purpose Tray
Thin 2
14 to 15 lb bond (52 to 59 g/m2)
Thin 1
16 lb bond (60 to 63 g/m2)
Plain 1
17 to 20 lb bond (64 to 75 g/m2)
Plain 2
21 to 24 lb bond (76 to 90 g/m2)
Plain 3
25 to 28 lb bond (91 to 105 g/m2)
Heavy 1
29 to 34 lb bond (106 to 128 g/m2)
Heavy 2
35 to 40 lb bond (129 to 150 g/m2)
Heavy 3
56 to 60 lb cover (151 to 163 g/m2)
Heavy 4
61 to 66 lb cover (164 to 180 g/m2)
Heavy 5
67 to 80 lb cover (181 to 220 g/m2)
Heavy 6
82 lb cover to 140 lb index (221 to 256 g/m2)
Heavy 7
100 to 110 lb cover (257 to 300 g/m2)
Recycled 1*1
Recycled 2*1
Recycled 3*1
Color
17 to 21 lb bond (64 to 81 g/m2)
Pre-punched
Transparency*2
32 lb bond to 80 lb cover (121 to 220 g/m2)
Tracing*3
1-Sided Coated
29 lb bond to 60 lb cover (106 to 163 g/m2)
61 to 80 lb cover (164 to 220 g/m2)
2-Sided Coated
Labels
31 lb bond to 68 lb cover (118 to 185 g/m2)
Bond*5
22 to 26 lb bond (82 to 99 g/m2)
Tab
*4
*4
*4
56 to 80 lb cover (151 to 220 g/m2)
*4
Letterhead
Envelope
20 to 28 lb bond (75 to 105 g/m2)
*1 You can use 100% recycled paper.
*2 Use only LTR transparencies made especially for this machine.
*3 Some types of tracing paper cannot be used.
*4 Tab paper can only be loaded in paper drawer 2.
*5 This paper type can be registered when LTR, LTRR, or EXEC paper is loaded in a paper source.
Paper Available when Copying
Use any of the following paper when making 2-sided copies.
Paper size:
12" x 18", 11" x 17", LGL, LTR, LTRR, STMTR, EXEC, Custom Size (5 1/2" x 7 1/8" to 12 5/8" x 18" (139.7 x 182.0 mm to 304.8 x 457.2 mm)*1
Paper weight:
14 lb bond to 80 lb cover (52 to 220 g/m2)
*1 Free size paper and envelopes are not available for 2-sided copying.
Finishing functions are not available when making copies on free size, custom size paper, transparencies, tracing paper, labels, tab, or envelope.
If you set Heavy 6 for cover on<Copy> <Options> <Booklet>, you cannot use the settings other than <Front Cover> and <Back Cover> to make copies.
Do not use the following paper when using Document Scan Lock. Doing so may prevent scan lock information and tracking information from being embedded properly.
Highly transparent paper such as Thin, Transparency, Tracing, and Color.
Paper Available when Printing
Depending on paper size and type, 2-sided printing may not be available.
13WJ-0H3
