Operating Modes
Auto, PS, PCL, XPS, Imaging, and PDF
Resident Fonts
PCL:93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T*1 (Japanese, Korean, Simplified and Traditional Chinese) , Barcode fonts*2
PS:136 Roman
Printable Area
PCL5c and PCL6:Reduced to 3/16" (4.2 mm) from the top, bottom, left, and right edges of the paper.
PostScript 3:Reduced to 3/16" (4 mm) from the top, bottom, left, and right edges of the paper.
When printing in the Expand Print Region and Print mode, the upper margin becomes 3/16" (4 mm), the lower margin becomes 1/8" (2.5 mm), and the side margins both become 1/8" (2.5 mm). The printable area is enlarged.
When an original has data that extends all the way to the edges, even if you select [Expand Print Region and Print], the periphery of the data may be cut off when printing. In this case, specify the reduction ratio in the printer driver so that data is not cut off, and perform printing again.
