Paper Sizes
Max: 12 5/8" x 18" (320 x 457.2 mm)
Min: 3 7/8" x 5 1/2" (98 x 139.7 mm)
Paper Weight
14 lb bond to 110 lb cover (52 to 300 g/m2)
Paper Type
All the paper that can be fed
Capacity Per Tray*1
Upper Tray (Tray B)No finishing set, Collate, Group mode:
LTR, EXEC, STMT, and STMTR: 250 sheets (or 1 7/8" (47 mm) in height)
12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, and LTRR: 125 sheets (or 1" (24 mm) in height)
Collate + Offset, Group + Offset mode:
LTR and EXEC: 250 sheets (or 1 7/8" (47 mm) in height)
11" x 17": 125 sheets (or 1" (24 mm) in height)
With different paper sizes: 125 sheets (or 1" (24 mm) in height)
Lower Tray (Tray A)No finishing set, Collate, and Group mode:
LTR, EXEC, STMT, and STMTR: 3,000 sheets or height 16 5/8" (423 mm)*2
12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, and LTRR: 1,500 sheets or height 8 1/2" (216 mm)
With different paper sizes: 1,500 sheets (or 8 1/2" (216 mm) in height)
Collate + Offset and Group + Offset mode:
LTR, EXEC: 3000 sheets or height 16 5/8" (423 mm)*2
11" x 17", LGL, LTRR: 1500 sheets or height 8 1/2" (216 mm)
Staple (Corner/Double):
LTR and EXEC: 200 sets/total 3,000 sheets (or 16 5/8" (423 mm) in height)
11" x 17", LGL, and LTRR: 100 sets/total 1,500 sheets (or 8 1/2" (216 mm) in height)
Staple (Staple-Free):
LTR: 200 sets
11" x 17": 100 sets
Inner Tray (Tray C)100 sheets (21.7 lb bond (81.4 g/m2))
Staple
Max. Stapling Capacity*3Staple (Corner/Double):
LTR and EXEC: 50 sheets (24 lb bond (90 g/m2))
11" x 17", LGL, and LTRR: 30 sheets (24 lb bond (90 g/m2))
11" x 17" and LTR:
5 sheets (14 to 17 lb bond (52 to 64 g/m2))
4 sheets (17.3 to 21.7 lb bond (65 to 81.4 g/m2))
3 sheets (21.7 to 28 lb bond (81.5 to 105 g/m2))
Manual Staple:
All sizes:50 sheets (24 lb bond (90 g/m2))
Punch
(When the puncher unit is attached)
Paper SizesTwo/Three Holes:
Max: 11" x 17"
Min: EXEC
Paper Weight14 lb bond to 110 lb cover (52 to 300 g/m2)
Punch HoleTwo/Three Holes
Dimensions (W x D x H)/Weight
21 1/8" (25 1/8"*4) x 24 1/2" x 43 1/8" (45"*4) (537 mm (637 mm*4) x 623 mm x 1,095 mm (1,142 mm*4))/Approximately 68.3 lb (31 kg)
Installation Space Including the Main Unit
(W x D)
62 3/8" x 29 1/4" (1,585 x 742 mm) (when the auxiliary tray is extended)
