Inner Finisher-H1
Paper Sizes
Max: 12 5/8" x 18" (320 x 457.2 mm)
Min: 3 7/8" x 5 1/2" (98 x 139.7 mm)
Paper Weight
14 lb bond to 110 lb cover (52 to 300 g/m2)
Paper Type
All the paper that can be fed
Capacity Per Tray*1
Upper Tray (Tray B)
No finishing set, Collate, and Group mode:
45 sheets (or 1/4" (5.2 mm) in height)
Lower Tray (Tray A)
No finishing set, Collte, and Group mode:
LTR, EXEC, STMT, and STMTR: 500 sheets (or 2 1/8" (52 mm) in height)
12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, and LTRR: 250 sheets or height 1" (26 mm)
With different paper sizes: 250 sheets or height 1" (26 mm)
Collate + Offset and Group + Offset mode:
LTR, EXEC: 500 sheets (or 2 1/8" (52 mm) in height)
11" x 17", LGL, LTRR: 250 sheets or height 1" (26 mm)
Staple (Corner/Double) mode:
LTR and EXEC: 30 sets or height 2 1/8" (52 mm)
11" x 17", LGL, and LTRR: 30 sets or height 1" (26 mm)
Staple (Staple-Free) mode:
LTR: 30 sets or height 2 1/8" (52 mm)
11" x 17": 30 sets or height 1" (26 mm)
Staple
Max. Stapling Capacity*2
Staple (Corner/Double):
LTR and EXEC: 50 sheets (24 lb bond (90 g/m2))
11" x 17", LGL, and LTRR: 30 sheets (24 lb bond (90 g/m2))
Staple (Staple-Free) :
11" x 17" and LTR:
5 sheets (14 to 17 lb bond (52 to 64 g/m2))
4 sheets (18 to 21 lb bond (65 to 81 g/m2))
3 sheets (22 to 28 lb bond (82 to 105 g/m2))
Manual Staple:
All sizes:
50 sheets (14 lb bond (52 g/m2))
45 sheets (17 lb bond (64 g/m2))
40 sheets (20 lb bond (80 g/m2))
Punching
(When the inner puncher unit is attached)
Paper Sizes
11" x 17" to EXEC
Paper Weight
Punch Hole
Two/Four Holes or Two/Three Holes
Dimensions (W x D x H)/Weight
18 3/8" x 20 5/8" x 8 7/8" (466 x 525 x 225 mm)/Approximately 18.3 lb (8.6 kg)
Installation Space Including the Main Unit
(W x D)
42" x 29 1/4" (1066 x 742 mm)
*1 For 81.4 g/m2 paper only. Capacity varies in other cases.
*2 When the standard staple cartridge is attached. (The maximum stapling capacity may vary, depending on the paper type and weight.)
13WJ-0FJ
