System Requirements
The following system environments are necessary in order to use the scanner driver.
Software:
Operating Systems:
Windows XP
Windows Server 2003
Windows Vista
Windows Server 2008
Windows 7
Applications:
TWAIN-compatible applications (Adobe Acrobat, Microsoft Word/Excel/PowerPoint etc. in Office 2000 or later)
Hardware:
Computer
Any computer that runs the above systems
Hard disk space
Any hard disk with the capacity required to operate the compatible operating systems
Main memory
Any memory with the capacity required to operate the compatible operating systems
A display with a resolution of at least 640 x 480 (800 x 600 or more recommended) and capable of displaying at least 256 colors.
A network host adapter capable of TCP/IP and UDP/IP communication on an Ethernet network.
When scanning large numbers of images or images containing large amounts of image data, an insufficient memory error or notable loss of scanning speed may occur. If this happens, the following procedures should prove useful.
Increase the amount of hard disk space by deleting or otherwise appropriately processing unnecessary files on the hard disk etc. to ensure sufficient hard disk space.
Rescan with reduced resolution.
Increase the amount of RAM.
Increase the amount of virtual memory to the highest possible.
Divide originals into several sets and then scan them separately.
» Scanner » System Requirements
08JK-1ER
