Giving Priority to Image Orientation
If Image Orientation Priority is set to 'On', the machine always copies an image in the same orientation as the original image. This is because the images on originals may be copied upside down, depending on the copy mode set.
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
If Image Orientation Priority is set to 'On', the copy speed is slower than normal.
Press
(Settings/Registration).
Press [Function Settings] → [Copy] → [Image Orientation Priority].
Press [On] → [OK].
Select [Off] if you do not want to enable the Image Orientation Priority mode.
