Changing the Puncher Die Name
You can change the name of puncher die in the Professional Puncher-C1.
This mode can be set when the Professional Puncher-C1 is attached. For more information on the Professional Puncher-C1, consult the instruction manual that comes with it.
Press [Preferences] → [Display Settings] → [Edit Puncher Unit Die Name].
Select the puncher die that you want to edit from the list → press [Edit].
4.
Enter a name → press [OK].
» Settings/Registration » Preferences » Display Settings » Changing the Puncher Die Name
08JK-06Y
