Paper Decks of the Multi-drawer Paper Deck-A1 (Optional)
Follow the procedure described below, while referring to the location of the paper jam and the directions that appear on the touch panel display, to remove the jammed paper.
The following illustration indicates the location of the paper jam. Please refer to it to remove the jammed paper.
Remove any paper jammed in the paper deck.
1. Push the open button of the paper deck indicated on the touch panel display.
2. Grip the handle, and pull out the paper deck until it stops.
3. Remove any jammed paper.
If the machine is in the Sleep mode (the touch panel is not displayed, and only (Energy Saver) is lit), you may be unable to open the paper deck unit. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the paper deck unit.
Do not pull out the paper deck by force.
Gently push the paper deck back into the machine until it clicks into place in the closed position.
CAUTION
When closing the paper deck, be careful not to get your fingers caught, as this may result in personal injury.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper am is cleared.
» Problem Solving » Clearing Paper Jams » Paper Sources » Paper Decks of the Multi-drawer Paper Deck-A1 (Optional)
08JK-0L8
