Front Cover of the Multi-drawer Paper Deck-A1 (Optional)
Follow the procedure described below, while referring to the location of the paper jam and the directions that appear on the touch panel display, to remove the jammed paper.
The following illustration indicates the location of the paper jam. Please refer to it to remove the jammed paper.
*Front Cover
Close the cover that is open.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
Open the front cover of the Multi-drawer Paper Deck-A1.
Remove any jammed paper from the guide (D-A1).
1. Open the guide (D-A1).
2. Remove any jammed paper.
4.
Turn the dial (D-A2), and remove any jammed paper.
1. Turn the dial (D-A2) in the direction of the arrow (counterclockwise).
5.
Remove any jammed paper from the guide (D-A3).
1. Open the guide (D-A3).
6.
Turn the dial (D-A4), and remove any jammed paper.
1. Turn the dial (D-A4) in the direction of the arrow (counterclockwise).
7.
Close the guide (D-A3).
CAUTION
When closing the guide, be careful not to get your fingers caught, as this may result in personal injury.
8.
Close the guide (D-A1).
CAUTION
9.
Remove any jammed paper from the guide (D-B1).
1. Open the guide (D-B1).
10.
Turn the dial (D-B2), and remove nay jammed paper.
1. Turn the dial (D-B2) in the direction of the arrow (counterclockwise).
11.
Close the guide (D-B1).
CAUTION
12.
Close the front cover of the Multi-drawer Paper Deck-A1.
CAUTION
13.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
» Problem Solving » Clearing Paper Jams » Paper Sources » Front Cover of the Multi-drawer Paper Deck-A1 (Optional)
08JK-0L7
