Previewing a File
You can preview files stored in a folder.
Press [Access Stored Files] → [Advanced Box].
Select the desired storage space → select the directory where the file you want to preview is stored.
Select the desired file → press [Display Image].
If you select multiple files and press [Display Image], only the contents of the selected (highlighted) file are displayed.
To preview a PDF file, the PS Printer Kit or Direct Print Kit (for PDF/XPS) is required.
To preview an XPS file, the Direct Print Kit (for PDF/XPS) is required.
To preview an encrypted PDF file, it is necessary to enter the password on the password entry screen.
To preview a PDF file with a policy, it is necessary to enter the user information on the login screen.
4.
Press [OK].
» Access Stored Files » Arranging Files and Folders Stored in the Advanced Box » Previewing a File
08JK-17E
