Printing a File in a Confidential Fax Inbox
Press [Fax/I-Fax Inbox] → [Confidential Fax Inbox].
Select the desired inbox.
Select the file that you want to print → press [Print].
4.
Press [Start Printing].
If you want to automatically delete the selected file after it is printed, press [Delete File After Printing].
You can print stored files only with the same settings as when they were received.
You cannot print multiple files simultaneously. To print multiple files, select and print one file at a time.
» Fax/I-Fax Inbox » Confidential Fax Inbox » Printing a File in a Confidential Fax Inbox
08JK-1A8
