A maximum of 32 files can be selected and sent at the same time.
A maximum of 999 pages can be sent simultaneously.
If the destination is stored in the Address Book:
Refer to the following, depending on the type of address book.
Scan and Send:
Fax:
If the destination is stored in a One-Touch button:
E-Mail, I-Fax, File Server, Advanced Box:
Fax:
If the destination is not stored in the Address Book:
Refer to the following detailed procedures, according to the address or server to specify.
If the destination is stored in Favorite Settings:
If you want to specify your personal folder as the destination:
If you want to specify your own e-mail address as the destination:
If you want to specify Cc and/or Bcc addresses:
If you set an address type to 'On' in [Limit New Destination], you cannot enter new destinations of that type. Select a stored destination by using the Local Address Book, Remote Address Book, LDAP Server in [Address Book], or by pressing a one touch button in [One-Touch]. (See "Restricting the Send Function.")
You can specify and send to up to 256 destinations at the one time. However, if a group address is specified for the destination, each address stored in that group is counted as one destination.
If you try to send to a file server for which [Confirm Before Sending] is set to 'On', a screen appears prompting you to enter a password. In this case, enter the server password. However, you cannot send to a group address including a file server in which [Confirm Before Sending] is set to 'On'. (See "Registering a File Server Address.")
If you want to automatically delete the selected file after it is sent, press [Delete File After Sending].
You cannot print or store the file in a mail box while it is being sent.
If the selected destination is a group address which contains a mail box, the file you are sending will not be sent to (or stored in) that mail box.
Some file formats require optional products. For information on the optional products required to use this function, see "Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
For more information on file formats, see "Setting the File Format."
For more information on option modes, see "Scan and Send" or "Sending/Receiving a Fax."
