Network Environment Setup Procedures
Before using the machine in a network environment, it is necessary to perform the following setup procedures.
1 Connecting the Machine to a Computer or Network
Connect the machine to the network using the network cables.
2 Interface Settings
Specify the interface settings for communication between the machine and computers on your network. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
3 Communication Environment Setup
Set up the environment for communication between the machine and computers on your network.
4 IEEE802.1X Authentication Settings
Specify the settings of IEEE802.1X authentication.
If you are using the imagePASS or the ColorPASS, see the manual provided with the imagePASS or the ColorPASS.
If you are using the imagePASS or the ColorPASS, some functions are not available with this machine. For details, see the manual provided with the imagePASS or the ColorPASS.
» Network » Network Environment Setup Procedures
08JK-1YH
