Adjusting the Position and Angle of the Touch Panel Display (Upright Control Panel)
You can adjust the position and angle of the control panel. Adjust the position and angle of the control panel if the touch panel display cannot be seen clearly.
Hold the control panel with both hands, as shown below.
Slowly adjust the position of the control panel.
You can adjust the angle, as indicated below. If you exceed the adjustment range in any direction, you could break the arm that supports the control panel.
*1 25° Up
*2 15° Down
*3 57° Sideways
Slowly adjust the angle of the control panel.
*1 40° up and down
*2 80° Sideways
» Basic Operations » The Touch Panel Display » Adjusting the Position and Angle of the Touch Panel Display (Upright Control Panel)
08JK-016
