Setting Up an Advanced Box on the Same Network
To setup an Advanced Box on the network, it is necessary to perform the following procedures:
1. To make an Advanced Box accessible on the network, specify the settings on the machine with the Advanced Box to be shared.
For more information, see "Opening the Advanced Box of the Machine Externally on the Network."
2. Connect the machine to the network.
3. Set the machine to use the TCP/IP network.
4. Specify the settings on the machine for using an Advanced Box on the network.
5. Specify the settings on the machine required to display an Advanced Box on the network.
To Practical Workflows
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Sharing Sent Fax Documents in the Advanced Box
Sharing Received Fax Documents in the Advanced Box
Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
Creating Address Labels by Scanning Business Cards
» Flow of Settings » Setting Up an Advanced Box on the Same Network
08JK-00F
