Setting the Memory Lock Mode
You can set to store received fax documents in the Memory RX Inbox without printing them. You can later check the received documents in the Memory RX Inbox, and print or send them as necessary.
If you set [Fax Memory Lock] to 'On', you can specify the settings for <Fax Memory Lock> for the Memory RX Inbox as necessary. (See "Specifying the Fax/I-Fax Inbox Settings" and "Memory RX Inbox.")
To receive documents in memory, you must first set [Use Fax Memory Lock] or [Use I-Fax Memory Lock] to 'On'. (See "Specifying the Fax/I-Fax Inbox Settings.")
You cannot store received documents in memory in the cases below. These numbers may vary depending on the remaining capacity of the hard disk.
When a total of 1,500 documents or images are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 6,000 pages of documents or images are stored in the Mail Box and Fax/I-Fax Inbox
» Fax » Sending/Receiving a Fax » Setting the Memory Lock Mode
08JK-0YC
