Required Condition
Network settings are set.
The printer driver is installed.
If you click [Get Device Status] on the [Device Settings] sheet, Mail Box names that were registered using the machine are reflected on the printer driver.
You can also set to print a document at the same time it is stored in the Mail Box.
If the Main Menu screen is not displayed, press (Main Menu).
You can select multiple files stored in the Mail Box and send them at once.
You can enter a new destination on the Send Settings screen from the control panel of your imageRUNNER ADVANCE. When sending from the Remote UI, you can only select the destinations that are stored in the Address Book.
You cannot send CMYK data that was output and stored with a PS server or a compatible PS.
Type
Mail Box
Scan and Send
Documents Sent from a Computer
Print
(incl. Printing after merging) |
Yes
Yes
Yes
Change Print Settings
No. of print sets
Yes
Yes
Yes
Select Paper
Yes
Yes
Yes
2-Sided printing
Yes
Yes
Yes
Finishing
Yes
Yes
Yes
Staple
Yes
Yes
Yes
Saddle Stitch Booklet
Yes
Yes*1
Yes
Gutter
Yes
Yes
Yes
Cover/Job Separator
Yes
Yes
Yes
Page Numbering
Yes
Yes*1
Yes
Superimpose Image
Yes
Yes*1
Yes
Secure Watermark
Yes
Yes
Yes
Merge and Store
Yes
Yes*1
Yes
Move/Duplicate
(Moving to another Mail Box) |
Yes
Yes
Yes
Clear
Erase Document
Yes
Yes
Yes
Erase Page
Yes
Yes
Yes
Insert Document
Yes
Yes
Yes
Sending Documents
Yes
Yes
Yes*2
Backing Up Stored Data
Yes
Yes
Yes
Storage Capacity
Total
1,500 documents
Each Mail Box
1,500 documents
E-mail settings are set.
(1)
Press (Settings/Registration) → [Function Settings] → [Store/Access Files] → [Mail Box Settings] → [Set/Register Mail Boxes].
(2)
Select the desired Mail Box.
(3)
Press [URL Send Settings] → select the destination (e-mail address/group) from the Address Book.
The machine is now set to automatically send an e-mail with a URL link to the location of the stored document.
If you scan documents from the Scan and Send screen, press [URL Send] on the screen for specifying the storage location.
(1)
Access the Remote UI → click [Access Received/Stored Files] → [Mail Box] → click the number of the Mail Box for which to set URL Send.
(2)
Click [Settings...] → select [Set URL Send] → click [Select Destination...] → select the destination.
