Obtaining the Remote Address Book
You can specify the settings to view the address book of another imageRUNNER ADVANCE series machine (remote address book) that is opened externally on the network.
This mode can be set when the Remote Fax function is available for use. For information on the optional products required to use the Remote Fax function, see "Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Obtaining Address Books
You can set whether to use the remote address book.
Remote Address Book Server Address
You can specify the IP address or the host name for the imageRUNNER ADVANCE series machine (Remote Address Book Server) with a remote address book that is opened externally.
You can register the IPv4 (Internet Protocol Version 4) address and IPv6 (Internet Protocol Version 6) address.
Communication Timeout
If you set a time for Communication Timeout, obtaining address books is canceled when the Remote Address Book Server is not responding and the set time has elapsed.
Fax TX Line Auto Select Adjustment
You can set whether to automatically select the fax line instead of using the line registered to the recipient, when sending a fax to a destination obtained from a remote address book.
» Settings/Registration » Set Destination » Obtaining the Remote Address Book
08JK-0J5
