Press [Set Destination] → [Register Destinations] → [Register New Dest.].
Press [File].
4.
Press [Name].
5.
Enter a name for the file server → press [Next].
6.
Press the drop-down list → select an address list from Address List 1 to 10.
Address lists are a convenient way to classify destinations.
The file server address that you enter will be stored in the address list that you select here.
7.
Press the <Protocol:> drop-down list → select the protocol.
For more information on the available protocols, see "Specifying a File Server Using the Keyboard."
8.
Press [Host Name].
9.
Enter the host name → press [OK].
If you select [WebDAV] in <Protocol:>, press [Next].
10.
Press [Folder Path].
11.
Enter the path to the folder → press [OK].
12.
Press [User Name].
13.
Enter the user name → press [OK].
14.
Press [Password].
15.
Enter the password → press [OK].
If you set [Confirm Before Sending] to 'On', a screen to enter the registered password appears when sending to the registered file server.
If you want to register a file server in a group address, set this setting to 'Off'. If you set it to 'On', you cannot send to the group address.
For instructions on specifying each of the settings for FTP, Windows (SMB), and WebDAV, see "Specifying a File Server Using the Keyboard."
If you specify the destination that you set to 'On' for [Confirm Before Sending] as the forwarding destination, the screen to enter the password does not appear. The registered password is used and forwarding is performed.
16.
Press [OK] → [Close].
If you are performing Access Number Management for the Address Book, perform the following operation.
Press [Next] → [Access No.] → [Access No.].
Enter the access number using - (numeric keys) → press [Confirm].
Enter the access number again for confirmation → press [OK] → [OK].
If you set [Language/Keyboard Switch] to 'On' in [Preferences] (Settings/Registration), the host name and folder path may not be displayed correctly, and you may not be able to browse to them.
For information on the settings for searching and browsing file server hosts, see "Setting Up a Computer as a File Server" for the SMB/CIFS network and "Setting Up a Computer as a File Server" for the TCP/IP network.
UPN can be used only if you are sending to a computer belonging to a domain operated with Active Directory.
» Settings/Registration » Set Destination » Register Destinations » Registering a File Server Address
08JK-0HE
