You can specify settings to use the machine as the server-machine for Remote Fax.
For information on the optional products required to use this function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [Fax Settings].
Press [Remote Fax Settings] → [Use Remote Fax].
4.
Press [On] → [OK].
Select [Off] if you do not want to use the Remote Fax function.
