The PIN (Personal Identification Number) code prevents unauthorized personnel from making calls. To protect privileged access to the telephone lines, only authorized users are entrusted with the PIN codes for daily operations. Some PBX (Private Branch eXchange) systems require that a PIN code be entered when dialing a number to make a call or send a document by fax. Depending on the requirements of the PBX system, the PIN code may be entered either before the number as a prefix, or after the number as a suffix.
If your PBX requires a PIN Code to get an outside line, your machine can be set to prompt the user to enter the PIN Code before dialing.
For information on the optional products required to use this function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [Fax Settings].
Press [PIN Code Access].
4.
Press [On] → specify each setting → press [OK].
If you do not want to set the PIN Code, press [Off].
Details of each item are shown below.
[Option]:
If your PBX requires a PIN Code depending on the destination, select [Option]. If PIN Code Access is set to 'Option', the PIN Code key is enabled on the Fax screen.
[Prefix]:
If your PBX always requires a PIN Code before the destination, select [Prefix].
[Suffix]:
If your PBX always requires a PIN Code after the destination, select [Suffix].
