Setting the Line to Use When Sending
You can register the method for selecting the line to use for sending. You can also set to prohibit sending from a line.
For information on the optional products required to use this function, see "Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
You can use this mode if the Super G3 2nd Line Fax Board is added to the Super G3 FAX Board.
Press [Function Settings] → [Send] → [Fax Settings].
Press [Set Line] → [Select TX Line].
4.
Specify each setting → press [OK].
Details of each item are shown below:
[Priority TX]:
The line specified in [Priority TX] is selected to send if the line is not in use.
[Prohibit TX]:
The line specified in [Prohibit TX] is restricted. (The specified line is used only for receiving.)
Depending on the fax board installed, the lines that you can select vary as shown below:
If only the Super G3 FAX Board is installed: Line 1
If the Super G3 FAX Board and Super G3 2nd Line Fax Board are installed: Line 1, Line 2
If the Super G3 FAX Board, Super G3 2nd Line Fax Board, and Super G3 3rd/4th Line Fax Board are installed: Line 1, Line 2, Line 3, Line 4
You cannot set both [Priority TX] and [Prohibit TX] for the same line.
Set one single line for [Priority TX]. You cannot set all lines to [Prohibit TX].
Even if you set to prohibit using Line1 for sending documents, Line1 is still used for fax information services.
If you select another line in [Options], that setting takes priority.
» Settings/Registration » Function Settings » Send » Specifying the Fax Settings » Setting the Line to Use When Sending
08JK-0EL
