Enabling ECM Transmission
You can send fax documents using the Error Correction Mode (ECM).
ECM reduces the effect of system and line errors on documents that occur during sending or receiving with another fax machine that supports ECM.
For information on the optional products required to use this function, see "Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
If you want to transmit using ECM, it is necessary that ECM Transmission be set in both the destination machine and this machine. This function does not operate unless ECM is set in both machines.)
If the other machine does not support ECM, this setting is ignored.
If transmission speed appears to be extremely slow, you may be able to speed up transmission time by turning ECM 'Off'.
Press [Function Settings] → [Send] → [Fax Settings].
Press [ECM TX].
4.
Press [On] → [OK].
Select [Off] if you do not want to enable ECM transmission.
Even when you set ECM, errors can sometimes occur due to a poor telephone line connection.
If there is trouble with the line, it will take more time to send the documents.
» Settings/Registration » Function Settings » Send » Specifying the Fax Settings » Enabling ECM Transmission
08JK-0EA
