Changing the Default Screen for Fax
You can set whether to display the [Standard] or [Address Book] screen when you select a function from the Main Menu, when Auto Reset is activated, or when you press
(Reset).
This mode can be set when the Fax function is available for use. For information on the optional products required to use the Fax function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [Fax Settings].
Press [Default Screen].
4.
Specify the settings → press [OK].
Details of each item are shown below.
[Standard]: Displays the screen for specifying the destination.
[Address Book]: Displays the screen with the Address Book open.
