Dividing Data Into Chunks When Sending with WebDAV
You can divide data into chunks when sending with WebDAV.
Chunked encoding is a function for sending a file with an unknown size by dividing it into chunks of a known length. It enables the sending time to be reduced because it is not necessary to calculate the size of the file before sending it.
Press [Function Settings] → [Send] → [Common Settings].
Press [Use Divided Chunk Send for WebDAV TX].
4.
Press [On] → [OK].
Select [Off] if you do not want to divide data into chunks when sending with WebDAV.
You may not be able to send files with chunked encoding, depending on certain conditions for the WebDAV server and proxy server.
If you set [Use Divided Chunk Send for WebDAV TX] to 'Off', the speed when sending with WebDAV is slightly slower than normal.
» Settings/Registration » Function Settings » Send » Common Settings » Dividing Data Into Chunks When Sending with WebDAV
08JK-0CC
