(Settings/Registration).|
[Data Size Priority]:
The data size is small, but the image quality is low.
[Normal]:
The data size and image quality are in between those of [Data Size Priority] and [Quality Priority].
[Quality Priority]:
The data size is large, but the image quality is high.
This setting is disabled when sending a fax or I-fax.
If you scan an original with many colors when [Text] is selected in [Original Type], the data size and image quality will vary following compression, according to the selected image level. However, if the original is in monochrome or has few colors, it does not matter which image level you select.
