Automatically Enabling the Remote Scanner Function
You can set to automatically enable the remote scanner function when you press [Scanner] on the Main Menu screen.
This mode can be set when the Scan function is available for use. For information on the optional products required to use the Scan function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Scan Settings].
Press [Auto Online].
4.
Press [On] → [OK].
Select [Off] if you do not want to automatically make the machine go offline.
If the remote scanner function is enabled, scanning is not possible with [Copy] or [Scan and Store].
