Black Scan Speed/Image Quality Priority
You can set whether priority is given to scanning speed or to image quality when scanning the black and white original.
For information on the optional products required to use this function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Scan Settings].
Press [Black Scan Speed/Image Quality Priority].
4.
Select [Speed Priority] or [Quality Priority].
This function is not available if you are directly sending faxes in the Direct Sending mode.
