(Settings/Registration).|
[From 1st Page]:
Place the originals in the feeder again, and then restart scanning from the first page of the document. The originals will be fed automatically until the page of the document in which scanning is interrupted.
[From Suspnd. Original]:
Place the originals that were not scanned because of a paper jam in the feeder, and then start scanning all the remaining originals again.
This function is not available if you are directly sending faxes in the Direct Sending mode. If a paper jam occurs in the feeder when using this mode, the fax job will be canceled. You need to specify the send settings again.
Depending on the location of a paper jam, it can be difficult to determine until which page of the document scanning has been complete. If you set [From Suspnd. Original] for [Feeder Jam Recovery Method] and you do not find until which page the document has been scanned, it is recommended that you cancel the job, and then execute it again.
